4x4 drive issues
Koletrain
I have a 96 GMC Sierra Z71. I have replaced the actuator on the front diff. You can hear the transfer case get in 4lo 4hi and exit into 2hi. When I installed the new actuator still wouldn't engage (obviously why I'm posting lol). The 4WD drive fuse inside the cab fuse box was blown. Replaced it. Tried to engage to 4x4 again and it blew the fuse. Any ideas where to start?
The wiring between the transfer case and the front diff.  There's a sensor in the TC that notices if it's in one of the 4wd modes, that goes to the front diff and activates the actuator to lock the front diff.  Sensor/wiring/actuator.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
