Brand new in the box leveling kit see details below regarding applications. Asking price $75, US shipping only.
SMX-GM725 for standard Suspension
* If vehicle is equipped with Magnetic Ride Control please click the link bellow SMX-GM725M.
SMX-GM725M
MAXXStak 1.5 "/2"/2.25"/2.5" Adjustable Front Leveling Kit for 2007-2019 GM ½ ton trucks & 2007-2019 GM ½ ton SUV's
Applications:
2007-2019 Cadillac Escalade Std. EXT, ESV 4x4 / 2wd / AWD
2006-2013 Chevrolet Avalanche 4x4 and 2wd
2007-2019 Chevrolet/GMC Silverado/Sierra 1500 4x4 / 2wd / AWD
2007-2019Chevrolet/GMC Suburban/Yukon 1500/XL 4x4 / 2wd / AWD
2007-2019 Chevrolet/GMC Tahoe/Yukon STD and Z71 4x4 / 2wd / AWD
  • 1 month later...
I have to ask, because I simply don't know...but, will this work on my 2020 Sierra 1500 AT4?
A few questions:
1. Is this the SMX- GM725M kit for Magneride trucks?  The picture would indicate as such, but just want to make sure.
2. Does this require re-alignment of the front end?
3. Do you know if there are any GM warranty implications?
I'm interested, just need to confirm those items.
Thanks!
I had bought this kit for my previous 2018 Denali but ended up getting rid of it before installing this kit. So to be honest the new kit looks identical but I would maybe try emailing them to see if this would be compatible.
A few questions:
Thanks!
1. Yes, this is for the magnetic ride suspension that has the relocation brackets included.
2. I don’t think it’s required but recommended in the instructions it gives the wheel alignment specs to be performed.
3. The leveling kit will not void the warranty unless something breaks because of the kit. In that case of course it will not be under warranty.
Hope this clears up some of your questions.
PM incoming...
  • 3 weeks later...
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 420 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
