2020 2500 HD Sierra No Audio!!!
No audio whatsoever FM, Bluetooth, XM, nothing! 2nd time this has happened. Radio is not muted but acts like it is. 1st time truck parked overnight and fixed itself. This time unfortunately I am driving for 3 hours with nothing to listen to! Anyone out there know how to fix this?... Other than disconnecting and reconnecting the batteries which I have 2 of (diesel) or letting it sit overnight again!!!
This has happened to me as well - Adio would come on for 2-5 seconds then nothing - all audio was dead. Pull the passenger fuse box panel and remove the fuse F-41 "infotainment" count to 10 and replace.
Or disconnect the battery - I thought the fuse was easier. ONly happened once  - have 3700 on the odometer
Thank you DJalberta! I will try that if sitting over night doesn't work this time....or the next time it happens. I believe it has something to do with the auto shutoff &/or shutting the vehicle off while key fob is not in the truck. This is the only common denominator in both of my situations that I can think of.
I did not have an issue the first 5k miles on the truck. The last 3k miles this has happened a handful of times. Those miles all came in the last few weeks on a long trip pulling my trailer. Sucked not having my Sirius XM, Spotify or WiFi periodically for the wife and kids. Especially, since I pay a lot extra per month for all that ******.
I was wondering if it’s the satellite fin on the roof or if it’s software. To the person that took the fuse in and out, you’ve not had an issue since? How long has it been?
Thanks,
Nate
I feel your pain.  I'm having all sorts of problems with audio in my 2020 3500HD.  GM is blaming XM, but sometimes I have issues with FM and bluetooth as well.  My problems occur about 10% of the times I drive...but that number increases to ~50% when I have a trailer connected.  I think I have a bad head unit or a grounding issue somewhere.  This is getting frustrating.
Thanks,
Nate
So, I didn't have to pull the fuse as when I started my truck the next morning the audio was playing. If (& when I'm sure) it happens again I will pull the fuse & report back if that works.
This has happened several times, I called XM and fix as follows turn truck off wait 3 minutes open door wait another 3 minutes.  Start engine and everything works.  Sounds crazy but has fixed 4 times now
I have had similar issues. Make sure your iPhone isn’t plugged into a usb for short key cycles. That seemed to be my issue. I make sure my phone is unplugged on short key cycles and my audio always works again on restart. The truck does a full power cycyle after 5-10 mins between keycycles and driver door open and close. Try that if it does it again for shorter remedy.
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
