P0171 / P0174 codes
cashflow50
2003 GMC Yukon 4.8L
Don’t have those scanners that gives you extra data, just got a simple one that gives you the codes only. Well I’ve researched that it’s mainly a vacuum leak issue. I’ve checked all vacuum hoses and even used a smoker and can’t seem to find where the problem is. Is there a common area where this leak occurs? Man it’s like finding a needle in a haystack. Need help from the gm gurus. Thanks
A dirty MAF can erroneously cause those codes. It's an easy check given that you haven't found an apparent vacuum leak via your tests.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 960 Guests (See full list)
