Uca hitting coils on speed bump 3.5 knuckle kit
Have any of you other guys with the RC 3.5 knuckle kit experienced the UCA hitting the coil spring when going over a bump?  I’ve had the kit on my truck for about 3 weeks and while it was torn down I had some 5100’s put on to replace the Rancho. Yesterday I drove over a speed bump (at low speed, maybe 5 mph) and it happened.  Not that I go off road very often but it would make me feel uncomfortable if I had to go on something more than a beaten path.
