What up peeps. So I am new to the lift game and I am having trouble going back and forth between lift kits and wheel size. I've seen the sticky wheel post and the tire size but I haven't found what I am looking for so I was hoping to get your help from your experience. There is just so much to consider when you look at lift high, wheel size/width, off set, back spacing. I am looking for that 'just right" look.
I have a 2019 Iridescent Pearl White high country 6.2l 4WD and I want to put 35's on it. I was looking at the ReadyLift 4" SST kit with 35x11.50x20 Nitto Ridge Grapplers on 20x9 Bronze Fuel Rebels.
The ReadyLift Kit says 0 offset but the 20x9 wheels come in 1 or 20 offset. I dont want the tires tucked in the wheel well. I am ok with them sticking out a tad bit. Do I need spacers? Do I go 20x10 and cut? I've seen the black one that custom offset did with 20x10 and 33's with a -18 offset on 2.5 lift.
What is the feedback around the ReadyLift Kit? I considered the 6" kit to get 12.50 tires and 20x10 wheels but I ruled that out because I figured the 6" would give to much wheel gap between wheel and fender.
I know everyones experience is a little different but I appreciate all feedback. I've read where the ReadyLift kit is good and I've read where the geometry doesnt add up and your CV's are put in jeopardy.
Just looking for some guidance.
Figure stock offset on 9" wheels is 24 or so so you would be pushing the wheels out about an inch. I've seen people fit 35x12.5s on stock wheels with a 3.5" lift. But going 11.50 wide wheels instead of 12.5 might give you just enough clearance
On my denali, I have the stock 22s and will be doing 285 55 22s with a bds 4" and will clear no problem
Sent from my SM-N975U using Tapatalk
I have the ReadyLift SST on my AT4. Adds 2” to the OEM 2” lift so I’m at 4” total. I did change the UCA which really helps with geometry. Over 3k miles so far on this setup and no CV or CV boot issues or wear that I can see.
Running 20x9 with 0 offset. 305/55/20 (33x12.5)
Poke is about 1-1.25” with no spacers. 5e5abaf46707242132652b6b15fdcfa1.plist701e03be73e9f2389d5442beff5979d6.jpgb9b13fe5a27a134330fd0cafadac25fa.jpgb6292247b72bcbedcdd48cb80be79758.plistdacee03077e145ea558b8a21f52f23d0.plist73b0e751944f73c084a14f331f9d3045.plist
@loud_pipes I just realized you're running at 12.50 tire. So you have no rub issues? From what I was told I needed a 20x9 and an 11.50 tire. On 35's, maybe thats the difference?
Edited by Cobra003
[mention=219399]loud_pipes[/mention] I just realized you're running at 12.50 tire. So you have no rub issues? From what I was told I needed a 20x9 and an 11.50 tire. On 35's, maybe thats the difference?
Yep, that’s definitely the difference. You need 11.5 on 35’s. That’s specifically why I went with 33s - I wanted the extra width of the 12.5.
20x9 +1 offset Fuel Tech with nitto Ridge Grappler 33x12.5
0 offset is basically  the same as 1mm offset ( only 1mm difference) lots of rims offer that offset and not actually a true zero just so you know.
[mention=125934]Dirtbiker[/mention] Thank you. I looked at fuel's website and they show 20x9 is either a +1 or +20. But the 20x10's go to a -18.
[mention=204031]BlackRST[/mention] Did you do a lift or is that stock?
That's with a 2" readylift level kit up front. Sits level... .125 difference front to back. I highly recommend that kit based on quality and finished product specs. I didn't want to go with a full lift because I daily this, with my fiancé and 2 big dogs I don't want them jumping in and out on a lifted truck as they got older.
  • 6 months later...
any issues with the readylift level? Trying to decide between readylift bottom spacer or the rough country top spacer.
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
