My HMI module went out so I replaced the HMI module in my 2016 Denali. I put in the new HMI module and my navigation screen is saying theft locked. How do I get this removed?
You’ll need the VIN number of the car that has the HMI before, if it is new, you have to add your VIN using GM software.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
