So I started my truck this morning and none of the guages are working, all are pinned to the left, the speedometer same, digital speedometer at zero even when moving.  Brake light, airbag, traction control, all lit.  Have service warnings for anti theft, trailer brake, tire pressure start immediately after starting the vehicle.  Any help is greatly appreciated.
Bill
My gauges would go off and back on goin down the road, Flashing alarms like crazy, Long story short my mechanic stuck with it till he found it, He found a pin not making contact in a wire harness up in the head liner, Feeding the front camera...
Have you had anymore issues? Guess my luck ran out today/tonight with having no issues on my 2019 Silverado (purchased in October 2019 and just over 10,300 miles). The gauge cluster started showing all codes, all needles went to zero while moving (tachometer, speedometer, etc), and the a/c stopped working. I also noticed that the reverse lights and camera were both not working.
Has anyone else had this issue?
I ended up get'n rid of the 2019 and got a 2020 jus because I wanted the 10 speed tranny and adaptive cruise...
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,140 Guests (See full list)
