Don't know when it started doing it, but the driver's side seal/gasket, on the rear slider, has a 3" fold-over about halfway up.  I'll post a picture of it tonight, after my lunch break.
Thoughts/Suggestions on how to fix it?
Edited by Ravenkeeper
Added Picture
Just went out and took a few more pictures of the problem, and my temp-fix (goes back to the above as soon as I open/close it).
Slider closed with "issue."  ?
Slider open with "issue."  ?
Slider closed again, "issue" worse.  ?
Slider closed, after pulling the gasket/seal "reset."  ?
If I reopen the slider, the "issue" returns.  ?
Adding pictures
Put some blue painters tape on it overnight, stretching the gasket away from the fold to see if you can get it back to it's original memory.
  • 3 weeks later...
I've let it sit for a month, unfolded, and it would still do it.  When I took the above pictures, it was 3 months.  I'm going to leave it all summer, and probably into the winter, to see what happens.
I would dare offer using a heat gun to warm it slightly? But i wouldn't attempt it unless I had ZERO solution and I didn't want to buy another one...
Sent from my SM-N975U1 using Tapatalk
I don't think it will relax on it's own at this point, think you will have to "create a new memory point" for it.
@JimCost2014, Same suggestion as @VanguardK2 made?
I may just go for the replacement part.
[mention=144073]JimCost2014[/mention], Same suggestion as [mention=208304]VanguardK2[/mention] made?
If your going to replace it, I'd give the heat gun thing a go. Might as well. If it works it works, if its destroyed, your getting a new one anyway. Kinda can't lose when you have 2 of them [emoji848][emoji6]
  • 4 years later...
I was searching the web to find a fix and came across your thread, I was wondering if you found a part number? On the other hand I found a temporary fix find a black straw cut it the length of the fold and then slice the  length of the straw and slip it over the fold and when you open and close back slider the glass won't pinch the rubber seal anymore.
    Enduro73
    Enduro73
  • Who's Online   4 Members, 0 Anonymous, 1,069 Guests (See full list)
