Oiled my skidplate last night.
CityTruck
My front crossmember was about a 1/2 qt low so I filled it up too.  :(
You guys were right.  What a PITA.  I still thought I could do it neatly after all the warnings, but NO.  Looks like I'll need to get some ramps or something to get the front end up.  I was really surprised with all the oil that came out from the filter after I'd let the oil drain completely from the plug.  Anyway, just thought I'd share  :(
Are you talking about crankcase oil?  Transfer case oil?  Front diff fluid?
Sorry, I was a little vague.  I figured anyone that changes their own (engine) oil on a Z71 (or skidplate equiped) Silverado would know what I was talking about.  I really thought I could do it without making a mess.  I was able to get a rag on top of the skid plate and mop out most of it, but the cross member (which got drenched when I took the filter off) was impossible to clean.  I think if I just get the front end propped up a bit, it won't run down the groove in the skidplate (now I know why those holes are there ;)  ).  I'm not sure how to get the filter off without spraying oil everywhere though.  Anyway, like I said, I'm just sharing (for those that have been through this).
Sh*t, you should see the mess us 4x4 HD owners go through.  :(
A can of brakekleen and a rag will make it look like brand new under there again.
That's one more reason the $19.95 GM Goodwrench Plus 30 minute oil change is sooooo appealing to me!!!    :(
Heh, mine gets everywhere when I change the oil filter, it drips all over the front U joint and my T case skid plate....PITA but well worth doing my own, knowing it was done right(I hope!!!)
Hmm...I haven't had any problems yet when changing oil, but I always put something on the skid plate just incase, but no need for it so far.  But I guess I am just lucky or something.  But as usual I am sure to screw up and run out of luck sometime soon.
I have yet in 26K miles to leak any oil during a change onto the skid plate
Only time i make a mess is pulling the full pan from under the truck i get a tidal wave going and get the floor covered in oil.  My dad reallly gets POed.  Just throw some morter mix (works like oil dry) down and soaks it right up
It seems to have stopped dripping now (2 days later).  Will the BrakeKleen strip the waxy stuff the factory put on?  Thanks.
I'm not a master of the multiple quote thingy so I apologize in advance for the multiple replies    ;)
Yeah, I thought about that.  It's hard to find one that will use Mobil1 (oil and filter) and if you bring in your own oil and filter, it's not much cheaper.  Plus I like to look at the plug magnet and I like to make sure everything got tightened and it's a good opportunity to just check things under.  I do see the appeal though :(
I don't know if it would help, but how about trying one of those Fram Sure drain plugs?
I thought about that too, but I'm not sure I trust them (no reason for this lack of trust, just think the solid one looks safer).  Plus, the oil filter problem wouldn't be solved.  But I appreciate the idea.
What a drag, City!  I don't have that problem w/ the midrange suspension (forget the RPO), but seems that I usually end up getting some oil on something every time!  :(
About half the time I end up doing what Ryan mentioned and get the tidal wave over the edge of the pan when it catches on something in the driveway.  BTW, the regular clay type "kitty litter" works well in a pinch for oil spills.
You'd think Delco would have something like the Fram gadget?  I'll be in the same boat as the other Z-71 owners w/ the next truck, though.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
