No code with low idle and stalling on my 99 Sierra.
My boyfriends 99’ Sierra 4.8 V8 randomly started having a rough idle and began stalling then completely shutting off. The check engine light isn’t coming on for us to check a code, all plugs and coils seem normal. He filled his tank at a different gas station just last night and are wondering if this is a fuel pump/filter issue or could it just be bad gas? We are getting it towed home but without a code we don’t really know where to start.
I'd suggest starting with the fuel system, checking fuel pressure at the rail with a gauge.  Should be around 60 psi, both at idle, as well as when the engine is sped up (the pressure may dip while the engine is speeding up, but should quickly return to full pressure when the rpm levels out).
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
