Rear window slider not working
Rear window slider glass won’t work when switch pressed.2016 Silverado.  Possible fuses?  Or other causes. Worked last week.  Location of fuse indicates passenger side dash. Fuse 51 and 52. They cannot be seen in box but shows wrench in a box in diagram of panel for 3 fuses. Is it located under the fuse block or another location?  Thanks
