Hi everyone I have a question the automatic shift cable under the truck one of these black clips/ziptie has come loose what is the part number for it please and where can I find them?
Thank-You I have attached a photo as well of what I mean
I have no idea, good luck finding it. Without a dealership parts book, you probably won't get it.
Napa has a whole section on automotive body clips and wire harness clips.
I mean you could just go to the store or call the dealership if you really wanted to know, do some work on your own.
Edited by CamGTP
Go to local auto parts store...NAPA, Advance, Auto Zone, O'Reilly's, etc and look through their selection of body panel clips (or whatever they're called).  You'll likely find something there that will work or can be modified to work (or use a zip tie to tie it up out out the way)
It's not a GM OEM part, but if all you're needing is a clip to secure the cable...look through these; one of them is bound to work for you
https://www.oreillyauto.com/search/2001/gmc/sierra-1500?q=routing+clip
Edited by dsr611
I believe we have given you enough answer to help you out.
There isn't a part number break down on a part like that. It comes with the clips as part of the cable. Go to a parts store to find similar clips or go to a dealership and ask them if they have any.
Not sure how we can help you anymore than this.
12 hours ago, porra said:
Hi guys sorry about asking this again where can i find the proper zip ties / clips for the transmission cable?
Keep asking the same question and keep getting the same answers
GO TO LOCAL AUTO PARTS STORE...NAPA, ADVANCE, AUTO ZONE, O'REILLY'S, ETC AND LOOK THROUHGH THEIR SELECTION OF BODY PANEL CLIPS (OR WHATEVER THEY'RE CALLED).  YOU'LL LIKELY FIND SOMETHING THERE THAT WILL WORK OR CAN BE MODIFIED TO WORK (OR USE A ZIP TIE TO TIE IT UP OUT OF THE WAY)
IT'S NOT A GM OEM PART, BUT IF ALL YOU'RE NEEDING IS A CLIP TO SECURE THE CABLE...LOOK THROUGH THESE; ONE OF THE IS BOUND TO WORK FOR YOU
Or, better yet, why not just run to the local "pick a part" yard, crawl under a similar scrapped vehicle and get the part from it.  Then you know you're getting the right part
g help GIF
GM doesn't sell the same one outside of buying a new shift cable.  That said... you can try using this # 19130464.  Its a zip tie that has a "christmas tree" push pin end on it.
Edited by newdude
    250.3k
    Disabled Mike
    Disabled Mike
  • Who's Online   2 Members, 0 Anonymous, 737 Guests (See full list)
