I see a lot of topics regarding 18” rim or 20” but none in the 22” range. I was hoping to do some Nittos size 285/50R22 whereas the stock tire is a 275/50R22. Will the increase in size make clearance to avoid cutting on my truck?
I have Terra Grappler  G2 285/50s and have no rubbing problem. Tires look way better than the junk stock ones also. I have been very happy so far.
wurgs, thanks for the reply!
Did you use the stock 22" rims that are on the 2019 denali or did you go aftermarket? Could I see a picture?
Thanks!
I also have Nitto Terra Grappler G2 285/50/r22 with no problems. I had Nitto Ridge Grapplers in 285/55/r22 from the dealership and they rubbed so I had them replaced with these.
Cylon,
That setup looks great! Thanks for the info!  That pretty much settles the fact that I want those tires now.
@Wurgs, do you have a lift on your denali? Apparently the AT4 has a stock 2" lift the denali doesn't and I thought maybe that would create some rub potential.
No lift and have the stock rims. can try to post a pic tomorrow if you like.
Yeah that would be awesome if you could post a pic or two
Here's a couple. Tire is hair over 1/8" from rubbing. I have had them since last november and no issues and huge improvement from stock tires
    daveishi
    daveishi
  • Who's Online   6 Members, 0 Anonymous, 437 Guests (See full list)
