Locking rear cargo storage
TD32
I have a 2018 Tahoe. Any ideas how I can fit a lock on the rear cargo lift door? I'm talking about inside of the cab on the floor in the very back. Curious if anyone has seen a product for this yet or if I'm going to have to get crafty here.
not able to lock that, besides it would be easy to break into being plastic.
lots of options to replace that storage , but all the ones i see are a bit pricey.
https://www.bossstrongbox.com/police-tahoe-rear-storage
https://www.lockerdown.com/i-46-suvault-model-ld3003-2015-2020-escaladetahoe-yukon.html?ref=category:26
https://truckvault.com/vehicles/suv
https://suvcargocaddy.com/
https://www.tuffyproducts.com/product/290/tactical-gear-security-drawers
there are others, but guess i lost those bookmarks
The Lock'er Down Console is exactly what I'm looking for! The challenge with their design is the lock isn't flush with the top but it's close. Thank you for replying here.
FWIW, I have a console vault in the front and it's awesome:
https://www.consolevault.com/
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
