Stacking 2” Level with Bilstein 5100
Hi, I recently had a 2” RC leveling kit installed. My front still sits about 3/4” lower than the rear, and you can definitely still see the forward sweep. If I get the ride height adjustable shocks, am I able to set the fronts at 3/4 inch (or an inch if 3/4 not possible) while keeping the leveling block and even out the truck? I just didn’t know if you could stack these 2 together and still be able to add more height to my ride. Thank you
I'd experiment with different height blocks in the rear now before I would run a front leveling kit with adjustable shocks set to anything other than stock height.
