Wiring topper light access hole for wires in bed?
Just getting around to running wires from underneath the car up to inside ARE topper.  I have wires up inside the tail light housing.  Just need to know how to get them to the inside of the bed so I can then connect to wires from 3rd brake/dome light.
is there a access hole or do I have to drill one?  Thanks
GM has a designated terminal in the cargo lamp connector on the frame.  The center high mount lamps are known to leak on these trucks, so if you can avoid it, I'd use the wired circuits GM has.
Quote
#PIT5314C: CHMSL Wiring for Aftermarket Bed Cap Topper
2016-2019 model years
Perform the following recommendations based on vehicle configuration:
  1. For vehicles built WITH Under Rail Bed Lighting Option:
    Trucks equipped with the under rail bed lighting option will already have the female side of the X400 connector.  Obtain an appropriate length of 18 ga wire to run from the X400 connector up to the CHMSL wiring for the cap or topper.  Use terminal part # 60012931 in AFL Tray 21, along with wire seal  part # 60994015 in AFL Tray 21 and connect it to one end of the wire.  Disconnect the X400 connector and remove the rubber cavity plug in pin position 4 and discard.  Install the terminated lead that was just made into the X400 connector pin 4.  Run the wire up to the CHMSL for the cap or topper and connect.  The ground for the cap or topper CHMSL will need to be made to an appropriate ground.
  2. For vehicles built WITHOUT Under Rail Bed Lighting Option:
    Trucks not equipped with the under rail bed lighting option will have a dummy X400 female connector, which will be removed and discarded.  The female side of the X400 connector is not available separately, but can be obtained by ordering the under rail bed lighting harness GM part number 23327843.  The harness will come with terminals/wiring in pin positions 1 and 6.  Remove the wiring and terminal from pin location 1 and discard.  Move the rubber cavity plug from pin position 4 and reinstall it into pin position 1.  Obtain an appropriate length of 18 ga wire to run from the X400 up to the CHMSL wiring for the cap or topper.  Use terminal part # 60012931 in AFL Tray 21, along with wire seal part #  60994015 in AFL Tray 21 and connect it to one end of the wire.  Install the terminated lead that was just made into the X400 connector pin location 4.  Pin 6 is a ground circuit that is used for the under rail bed lighting and it can also be used to ground the CHMSL for the cap or topper if the wire gauge size in the connector is of the proper size for the CHMSL in the cap or topper.  If the wire gauge size is too small, any of the following can be done:
  • Make a second wire as described above.  Then, remove the wiring from pin 6 and discard.  Install the new terminated wire in position 6 for the ground and run it up to the CHMSL for the cap or topper and connect.
  • Remove the wire and terminal from pin 6 and install a rubber cavity plug.
  • Cut the wire for terminal 6, leaving a couple inches of wire, and seal the end of the wire.
Note: The terminal removal tool for the female side of the X400 connector is J-38125-212.
2014-2015 model years
    Trucks equipped with the under rail bed lighting option will already have an X6 connector at the rear body junction block X63A, which will be removed and discarded.   Obtain an appropriate length of 14 ga wire to run from the rear body junction block up to the CHMSL wiring for the cap or topper.  Use terminal part # 1-968857-3 in Lear Tray 7, along with wire seal  part # 828905-1 in Lear Tray 16 and connect to one end of the wire.  Disconnect the X6 connector at the Rear Body Junction Block and remove the rubber cavity plug in terminal position 1 and discard. Install the terminated lead you just made into the X6 connector terminal 1.  Run the wire up to the CHMSL for the cap or topper and connect.  The ground for the cap or topper CHMSL will need to be made to an appropriate ground.
    Trucks not equipped with the under rail bed lighting option will have a dummy connector at the X6 position of the rear body junction block. The X6 connector body is not available separately, but can be obtained by ordering the under rail bed lighting harness GM part number 22878806. The harness will come with terminals/wiring in positions 4 and 7. You will need to remove the wiring from terminal 4 and discard. Move the rubber cavity plug from terminal position 1 into terminal position 4.  Obtain an appropriate length of 14 ga wire to run from the rear body junction block up to the CHMSL wiring for the cap or topper.  Use terminal part # 1-968857-3 in Lear Tray 7, along with wire seal  part # 828905-1 in Lear Tray 16  and connect to one end of the wire. Install the terminated lead you just made into the X6 connector terminal 1. Terminal 7 is a ground circuit used for the under rail bed lighting and it can be used to ground the CHMSL for the cap or topper, if desired.  If terminal 7 is not used remove the terminal and install a rubber cavity plug or cut off the additional wiring, leaving a couple inches of wire and seal the end of the wire.
  1.
That’s the circuit I am using.  Wire is strung from that connector for th3rd brake light into the area behind the tail light.  I just need to know how to get it up and through the box to the interior of the pickup bed?
    • I just brought home a 2020 GMC 1500 Denali.  She has 53K miles on her and I want to change out the fluids over the next few weeks.  I see the diff covers don't have drain plugs.  Any suggestions where I can pick up front and rear diff covers with drain plugs?   Thanks,   Bob
    • Well, the dealership got the compressor and installed it. Air at the vents seems nice and cold as it should be. The service manager said the repair has a two year warranty and unlimited mileage. Hopefully I don't have to use it. The dealership i went to was one where I bought my 2014 half ton silverado. In 10 years and 168k miles on the truck anything I needed done and two small recalls they were always very good to me. Not a huge dealer either. I think they treat people well because they want you to come back. I have dealt with a different dealer that was too big to care about an individual. Just my two cents.
    • Hi All, I operate my 2021 3500 SLT most of the time with the tailgate off and in a crate because I have a slide-in camper. However, at least once a year, I take the camper off and put the tailgate back on. Recently I installed the tailgate, but had a hard time getting the connector bail to swing to the fully latched position. The connector seems to fully seat, and everything works, but the bail doesn’t swing to fully latched position.  It swings almost there but stops and I am afraid to push it any harder.    Does anyone have any advice on cleaning or lubrication or anything else I should be doing?  i know how to properly operate the connector. During the time the tailgate and connector are off, i have a double plastic bag over the truck connector secured with rubber bands to keep it clean, but it still had some dust in it this time when I blew it out with compressed air. I didn’t want to spray it with anything other than air without doing some research. Thanks.
    • There are a lot of spammer's that do that, quote something and add some commentary to make it seem legit, but modify the quoted text a bunch making sure when posted it's long enough to be "click to expand", and either immediately insert a spam link, or come back after some time and edit it to add the spam link.
    • Hello @jaszr2 Do you have a link for the item? I put a replacement bumper on my truck and consequently had to relocate the shutters. I studied on them a while, and figured if you left a couple key blades, you could get most of the airflow with probably no throwing codes.
