1 hour ago, RadoPhan said:
FYI if you’re running stock rims, the tires get really close to the UCAs. I have 295/70/18 on mine and here’s the clearance on it. Maybe 1/2” the most. I would bet that any wider would touch the UCA. b0969f0e5169e798eebea5d36f2b9929.jpg
Thanks for the pictures and information. That tire is getting really close to the UCA. I'm thinking about going with KO2's on my TB with standard 18" rims. Do you think these will fit with no problems? Stock TB suspension and will be putting either a  RC 1.5" level kit or a motofab 1" level kit. Haven't decided which on of these to put on yet.
  • Size: LT295/70R18
  • Side Wall: Black
  • Overall Diameter: 34.3"
  • Load ID: E
  • Max Load: 4080 lbs
  • Tread Depth: 15/32
  • Max PSI: 80
  • Speed Rating: R
  • Tread Type: All Terrain
  • Max Rim Width: 10
  • Tire Weight: 69.4 lbs
  • California Residents: WARNING
  • Size: LT295/70R18
  • Side Wall: Black
  • Load ID: E
  • Max PSI: 80
  • Speed Rating: R
  • Max Rim Width: 10
295s should be fine since majority are 11.6” wide but BFG KO2s doesn’t have that size. Use the link below to find the tire and look at the exact specs for each brand/model. Mine cleared on the stock rims and stock TB suspension. I was planning on the installing my Motofab 1” level too but I’ll avoid the UCA failure risk by doing the ReadyLift 1.75” with new UCAs. I’ll have to upgrade my rims with different offset to avoid it from rubbing the UCAs.
this is where I saw the K0's listed for sale.
https://www.4wheelparts.com/p/bf-goodrich-lt295-70r18-tire-all-terrain-t-a-ko2-26792/_/R-BDKZ-26792
I thought the same before but when I contacted America’s Tire they said the tire size didn’t exist. I also tried searching that part number on BFGs site and it doesn’t have anything under that part number.
https://www.bfgoodrichtires.com/search?q=BFG26792
Well ok then! That kind of sucks lol. I'm coming from a Gen2 raptor with K02's on it and I absolutely loved the tires. They were good on the trails and almost zero road noise rolling down the highway.
What size K02 you think is the biggest I can put on my TB with RC 1.5" level kit with zero lock to lock rubbing and ok with UCA?
I hear ya. I’ve done nothing but KO2s on my previous trucks and they are the BEST tire I’ve owned. The stock Wranglers are trash so I guess anything would be an improvement. I’m using Falkens now since it was the size I was going after and it had the best look and price was amazing (buy 3 get 1). I’m not sure if the KO2s in 305 would rub on the UCAs but you can always get 6mm spacers to push it out. Outside if that, the biggest one that will clear for sure in KO2 is 285/65 but that’s only 32.5” tall x 11.5” wide.
If I went the K02 305 route, how far would you think they would stick out using a 6mm spacer?
How would you compare the Falkens to the K02's? Where and when did you get that buy 3 get 1 free?
I think the 6mm spacer will definitely allow it to fit since it allows .23” backspacing and your only adding .4” total for the whole tire. It won’t stick too far out considering it only pushes it .23” out.
The Falkens have been pretty impressive so far and a lot of great reviews out there too. Super quiet on the road. I haven’t been able to test it offroad or in the rain yet but again, good reviews on that part too. It has an aggressive sidewall for an AT. But remember that these are an E rated tire so it’ll run a little stiffer than the stock C rated Duratracs. The original price was extremely good for that size. It’s weird because other sizes for this tire runs expensive similar to KO2 and Toyo prices and in some cases the KO2 is cheaper than Falkens in some sizes. Now add that on top of a 3 for 1 sale made it a no brainer. The sale is back on for Labor Day. What I did is price matched American Tire Depot’s sale and got them at America’s Tire. Comes out to $175 per tire. Can’t beat that price!!!
Ive contacted a few companies , readylift said the trail boss can fit 35” tires on stock rims as long as you stay at an 11.5” tire. This will clear the control arm that readylift supplies.
Some tires measure differently but the manufacturer will typically post proper measurements in the details on the tire size . So confirm actual measurement , some guys are running tires that are almost an 1” wider than what the tire size depicts.
I got 35x11.5 coming in a Nitto Trail Grappler , they actually measure 34.76” x 11.42” as shown below.
if you are wanting to run wider tires you could try a spacer , I think between a 1” and 1.25” get you around the same tire poke as a 0 offset rim. 1.5” would give you a little more.  The simpler solution would be to stay below 11.5”.
just remember the more negative the rim offset actually makes less tire clearance not more , thats where you get into trimming.
Edited by Chips
Thanks for the great information. I just emailed America's Tire to see if they would price match the 4 for price of 3 that America Tire Depot is offering. I'll let you guys know if they will match or not. If they will, I will order these! Like you said $175.50 is a no brainer and can't beat that. If they don't match I will probably wait until K02's go on sale somewhere and get the 305's.
Good luck! Is you used the found it lower link on their site and send them the link, they’ll approve it.
How would you guys compare the Falken Wildpeaks 295/70 compared to the Nitto trail grappler M/T 35/11.5?
Ride and road noise at highway speed etc?
I saw one member say the Falken 295/70 are actually 33.5 inches tall which is about 1 inch taller than factory tires (what he said). Are the Nitto indeed 35" tall?
The Falken 295/70 is actually 34.3”. I put it next to BFG KO2 35x12.50 and the height are almost exact which KO2 states theirs is 34.5”.
This is super helpful. Rookie question...will this be an issue when tires have been aired down for off road purposes?
That’s a good question. My guess would be no since it’s the bottom of the tire that gets pushed more than anything.
    daveishi
    daveishi
  • Who's Online   1 Member, 0 Anonymous, 996 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
