Just did a little cosmetic upgrade. I hated the exhaust pipe that’s just angled cut from the factory. So I cut it, painted it black and added a Borla 4” tip. I like the subtle upgrade.
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 5,964 Guests (See full list)
