Need some help I have a 97 Chevy 1500 that the battery is dead in couple days. I have disconnected my neg cable and put meter inline and found that I 9.75amp draw when truck is off started to pull fuses under hood got to the battery 50a mega fuse dropped down to .750 pulled ecm b dropped to .5.
Put 50a fuse back in went to interior panel found t-case fuse pulling over 2amp
Power accessories pulling over 2amp
radio pulling over 2amp
Security fuse 21 has 1amp
I have no clue where else to look for these draws I have almost unplugged every module Under dash that I can get to and only gotten it down to 6.5 with the aftermarket radio unplugged and some blue module with green connector unplugged.
Also unplugged 4wd actuator and push button no change to draw.
Any and all help would be great.
thanks
You need to find a schematic for the circuitry. Otherwise you are shooting in the dark. At first glance I would say to remove fuse box under the hood and check for corrosion underneat. I had a town and country that was draining the battery and I search for weeks looking for th eculprit. Turned out it was corrosion underneath the fuse box under the hood was shorting different things together. Funny thing is that everything worked. But the radio time would reset sometimes
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
