Hey everyone. So today my 2014 Silverado with 5.3 and 57 thousand miles on it. Started a nasty knock when it drops down into v4 mode. Truck runs great in v8 no check engine light or anything. Couldn’t find any one else with problems like this. Dealer can’t get the truck in till 2 days from now and the advice guy said it could be the exhaust also.
knock/reetard  had to miss spell it due to censoring the word r***rd
Edited by flyingfool
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and maybe memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.
