VIN Decoder for full-size trucks??
Evil SS
Does anyone have a VIN decoder for these trucks. I'm trying to figure out if any part of the VIN tells whether the truck is a stepside or not. If anyone knows just the answer to the stepside part it would be extremely helpful in my quest to find a truck when no picture is given....thanks guys!
