Hello all, I have a 2015 Suburban LTZ with 80k miles.  Started hearing a whine from the front left wheel over the past few weeks and worried it may be a transmission issue (based on previous ford expedition).  Before I take it in I thought I'd check on the warranty and found 5 year/60,000 mile.  Is that accurate as I thought I read somewhere it was 6 year/100,000 miles but can't find that info now.  Any input?  Thank you in advance!
Mike
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 846 Guests (See full list)
