I just ordered Mastercraft Stratus All Terrain tires for my Sierra.  Does anyone have any experience with these?
I wanted to go from a highway/street tire to an all terrain.
Thanks!
-R
It's a cooper tire in disguise, my works sells a ton of the cooper labeled ones that are very similar. No huge complaints that I hear of.
yes... I knew that they were made by Cooper in Texarkana, AR... but I just wanted to see if anyone had any bad experience with them.  Thank you sir!!!!
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 856 Guests (See full list)
