Need a help please. 2002 Silverado 1500 drains battery. Has “service 4wd” sign lit. Replaced selector switch, tccm, encoder motor. Cleaned the ground under driver side chassis. Still has the problem. “Atc” fuse reads active after Shutdown after a while. What is my problem??
It was radio Circuit that went haywire on mine that had a parasitic draw. Time to get the multimeter out and figure out which one of your circuits in the problem.
Get a Tech-2 on it so you can read the codes properly, diagnose the problem properly and fix it cheaply.
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
