I have a 2016 GMC Yukon Denali and I am having a really strange issue. I would appreciate any help you can give. Thanks!
Whenever it is in park and I press the brake, I get the following warnings.
-Service: Suspension System
-Sevice: Trailer Brake System
-Action Required: Steering Assist is Reduced Drive with Care
-Indicator Light for ABS, BRAKE and Traction Control
When I RELEASE the brake All warnings and problem indicator lights disappear and I get a "Service Traction Control" warning for a second and then that clears as well. As long as I am in gear I do not get any error indications even when the brake is pressed.
The cruise control doesn't work, but I believe that is the control switch assembly and a separate issue, but I wanted to mention it just in case there could be a correlation. In the case of the cruise, it is always "On" (white cruise indicator on the panel) but it will not allow me to "set".
Thank you in advance for your help!
Edited by Cameron Andrews
The first step is to take a deep dive into the codes, as these are ABS and Brake lights, you need to scan for the ABS system, usually there is really only one code and that code affects everything else. It is not unusual for the Cruise Control not to work if these systems are causing trouble as they are all integrated. Look for the lowest number code and work from there.
Check your ground wires. If damaged, they can play havock with your systems and make many codes display.
  • 5 years later...
...5 year old thread, and the o.p. hasn't returned to the site since signing up and making that one post.  you aren't going to get a response from that user.
    KJEK
    KJEK
  • Who's Online   1 Member, 0 Anonymous, 361 Guests (See full list)
