Put the RC 3.5" on my truck a few months ago and it rode stiff at first now the front end feels like a 60's model Lincoln. When driving the interstate it has that old car bounce in the front. Its hard to explain but its like a bounce/float feeling when hitting bad spots in the road. Would different shocks fix this or am I stuck with it on the RC 3.5?
