Anybody installed a tailgate seal with any luck? If so, how has it held up and did it actually stay on? Or did it start peeling off soon after? Tired of dusting all the equipment in my truck bed when running these powdery dust county roads during hunting season.
This one had the best reviews that I could find:
https://www.amazon.com/Ultimate-Tailgate-Seal-Taper-10ft/dp/B00IPQWXZQ
This is the kit I used to keep the dust out of my bed during hunting season.
https://www.accesscover.com/access-total-bed-seal/
It works pretty good. The tailgate seal alone didn't keep the dust out. The foam blocks in this kit helped a ton.
Sent from my SM-G975U using Tapatalk
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 1,404 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
