Hi I'm new here, tried to help a friend with his 2000 Serria 1500 we replaced the master cylinder and all the brake lines as they were leaking now I can't get the air out of the system, I've done this on my 2007 Serria 2500hd and bleed the system without any problems, trying to figure out what went wrong
What's going wrong?  You keep bleeding, but air is still present in the brake fluid coming out, or the pedal just seems soft?
How are you bleeding (what is the process you are using)?  And in what order are you bleeding the wheels?
Pedal goes to the floor no pressure even with the booster disconnected, bleeding from right rear to left rear to right front to left front, also tried to use a scan tool but wouldn't get connect to abs module, oh I'm using a self bleeding vacuum bleeding tool.
Darn, sometimes things don't work as planned,try to gravity bleed that front brake,crack bleeder,let it drip, tighten, check pedal,I'm thinking you are not getting a good seal on that bleeder with the vacuum tool
did you bench bleed the MC before hooking it up to the truck brake lines?
all the fittings look tight and no sign of a leak?
I'm not a fan of the vacuum bleeders, as they can suck air in via the bleeder screw threads (so it seems like you can't get the air out), but this doesn't seem to be your problem.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 481 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
