Need help,  I have the code p0449 I was told the vent solenoid was going so I replaced it.  Only to find I have low voltage coming to the plug.  Where so these wires go to.  I cannot find the information anywhere.
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 716 Guests (See full list)
