I have a 16 Sierra slt, I just noticed that my mirror switch has zero power, lights are off and I can’t adjust my mirrors. I took the plug off and tested the red wire, I have power at the wire. Does this mean the switch is bad? Recently I replaced my steering wheel (nothing crazy) so I had to unplug the battery. Any recommendations would be awesome!
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
