Lamin-X set up a coupon link for my YouTube channel so figured I’d share it here with you all.
This one is 20% off, pretty sure it works on all their products on their site but not totally sure. If anything the large rolls are off limits.
Navigate through the link, copy the code, add what you want to the cart, paste coupon code and complete your purchase.
I’ll share more codes as I get them. This one’s pretty solid.
https://go.referralcandy.com/share/624F3PC
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,379 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
