Hello All
I recently purchase new running boards to replace the stock silver ones that came on the truck when i purchased it. Would anyone in the Atlanta area be interested in buying them?
i would post them in the for sale forum but i dont have 50 post so i dont know if it is allowed. I attached a pic of them PM me if interested
Thanks
Edited by puppykat33
    thefultonhow
    thefultonhow
  • Who's Online   6 Members, 0 Anonymous, 682 Guests (See full list)
