Ok kinda of a odd mod but bear with me.
Doing a console swap this weekend. Truck A has Bose and full console which means it has a sub under the console. Truck B has no Bose and a jump seat.
Truck A will be getting a gm accessory under the rear seat sub woofer installed and the jump seat from truck B.
Truck B will be getting the center console, could careless if I add the Bose subwoofer to this truck.
Is it OK to remove the sub woofer assembly and leave it out on the truck that came with it? I would think yes?
FYI was no problem to remove the sub everything works with out it fine. Can be relocated below passenger seat or into the jump seat but a new box must be built to do so.
any pics of it?  heard it is a 4" sub...
The speaker it’s self is probably 4” the box is freaking huge. I think it uses the sealed box to add to the kick. Will be making the dude I swapped with a smaller box that either fits under the passenger seat or in the jump seat storage.
Sub is in my garage and I’m at the office but, here is a link.
https://www.carid.com/acdelco/gm-original-equipment-radio-speaker-mpn-22818981.html?view=838080&gclid=CjwKCAiA2O39BRBjEiwApB2Iklgqccj8ANV6kEizi9uMFMG6BgmKt85knB9gE68UsXD9c2z8XLpmKBoCum8QAvD_BwE
Not possible to add it to trucks that didn’t come with a factory subwoofer from what I can tell.
Side note, I’m going to look into upgrading the stock speakers on my truck, my 2016 sounded much better.
Thanks @Imcrazy - surprising sound for a 4" sub.  Think there is room to fit a 10" under the console?
Yeah, I had JL/Polk/Infinity setup in the last truck but honestly, dumping $2000 into this truck's sound isn't my first priority!
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
