Wanted to get some thoughts from people who have hardwired their dash cams, and specifically anyone who has a Nexar dash cam as well. I already found a great thread which was super useful but wanted to see other thoughts out there. I see there is the plug on the passenger side that I can tap into for power, but what about the garage door buttons? Can I get power from there? If so where do I need to tap into for it?
Any help is appreciated!
  • 2 months later...
You may have gotten an answer by now, but I tapped into the garage door remote  fuse for constant power, and the heated steering wheel for switched on power. Used a micro 2 fuse tap, both fuses are 5 amp. My dash cam is a BlackVue unit with front and rear
Edited by DarkSky20
Added info
