I have a 2015 Silverado with 105,000 miles on it. Did a full transmission flush about 3 months. Driving with no trailer for more than 2-3 hours at a time specifically in hill country the tranny temperature is running between 220 and 260 obviously very high. After a few hours if I am not babying it I will get the message " Transmission is hot let engine idle" If i let it idle for 60 seconds it drops 5-10 degrees and on the road again however the temp still remains way to high. If I am pulling a trailer of any kind flat bed, toy hauler it will over heat within 2 hours or so and again really having to baby it. I ran the computer on it and receive a Lost communications with TCM OBD-II trouble code. Now before i start swapping parts such as the TCM I am hoping for some ideas or suggestions with what is going on with it. Also occasionally maybe  3 times in the last year the rear tires with lock up in first gear for a 10th of a second just long enough to screech the tires. Once in a while there will be a hard shift doesn't matter if the truck is hot or cold and is rare but non the less happens.
Any ideas before I take it into the shop?
Could be stuck trans thermostat, that’s what happened to my truck.
It’s supposed to open up at 190-200F. This is how to diagnose.
The thernostat is basically attached to the trans on the outside. It allows flow to the trans cooler. When your trans is hot, feel both of the cooler lines. In my case it would allow a little bit of flow regardless of the temp. I don’t know if they are all like that. So my drivers side line was hot, burning hot. But the flow was so slow that it was ambient temp by the time it left the trans cooler. So I had one line hot and one line cold regardless of temp.
After I had the thermostat replaced. It was the same exact thing, only when I reached 190-200, the passenger side line was hot as well.
Both lines should be very hot when it’s flowing. Like too hot to hold onto.
The dealer was incapable of diagnosing this, I basically had to self diagnose and explain it to them.
I suppose it could also be low on fluid.
i would advise getting the trans fluid replaced as well
Lots of guys on here have done the transmission thermostat "Pill Flip" mod and have seen the trans temps drop to around 160 going down the road. Myself included. Takes about 20 minutes to do at most.
The wiring could be a bad harness inside the transmission if you are losing communication to the TCM.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 463 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
