I'm planning to redo my Z71 and Duramax badges to match whichever wheels I end up with. This mostly started with trying to match bronze since I think the stock chrome badges would clash. If anyone is de-badging their trucks and taking off the duramax hood badge or Z71 fender badges I will gladly pay shipping and take them off your hands so I have something to practice on. Send a PM and we can work out the details.
Edited by KADE206
