We have a 2000 Suburban 1500 4x4 that my wife inherited from her mother. We've been fixing all the little things here and there, but we're having an issue with the battery draining. If it sits for more than a day the battery goes dead. We've replaced the battery a couple of times in the last 2-3 years. I've used a multimeter and pulled fuses one at a time, but don't see a constant draw. I've disconnected the VCR and power inverter. It has an aftermarket radio, and I've pulled that fuse. Still no luck. One strange thing I've noticed is that it won't run with the battery charger connected. It will start, but dies as soon as I release the key. As soon as I disconnect the charger after charging it, it starts fine. I'm stumped. Is it possible there is an issue with the alternator and/or voltage regulator? Is there something else I may have missed?
  • 1 year later...
An update on this. The issue still exists. Alternator tested fine at AutoZone and we've gone through a few batteries, so neither is the issue. It's not a constant or predictable drain. I've let it sit 2-3 weeks and it started fine. Last week I drove it around for a few hours after the battery was fully charged, and the next morning it was dead.
One odd thing I've noticed. When charging or jumping the battery, it will start and then die if the external power source is connected. I have to charge the battery, disconnect the charger, and then start it. I've never seen that before. I've put a volt meter inline on the positive side and have never seen any abnormal draw. I've randomly pulled fuses but haven't seen any significant or unexpected change in draw. I've pulled fuses and let it sit overnight and still came out to a dead battery.
I've been to a couple of shops and they can't figure it out.
This vehicle has sentimental value to my wife so we will never get rid of it. If necessary, I'll start replacing electronics one at a time, and the wiring harness if it comes down to it. But I sure don't want to go down that road if I don't have to.
  • 1 month later...
FINAL UPDATE: I bought an Optima Yellow top battery. At over $300, I'll admit it was reluctantly. I started it to make sure all connections were good and shut it off. The Suburban sat untouched for 9 days and it fired right up. I let it run a while to warm up and turned it off.
It has now sat untouched for over two weeks. This morning it's 42 degrees in SE Texas. The Suburban fired right up with no hesitation.
I've installed multiple new batteries in it the last several years since we've had this parasitic drain, multiple brands. I have read about the electronics drain on batteries from this model. I don't know if the quality of batteries has declined, or if the Yellow Top is just able to mask or compensate for the issue, but it is fixed enough for me. We'll see how the Optima does over time, but I'm happy.
I’ve had two vehicles of different brands drain batteries after two weeks not being driven. Three when the battery was new. The only common theme was aftermarket alarms.
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,588 Guests (See full list)
    • So I'm in the middle of a DOD AFM delete on my 6.2 L86 Sierra. I had a pick holding the tensioner but after I got the Cam phaser gear off I was cleaning off all the rtv and apparently I didn't have the pick seated far enough in. I bumped it and the tensioner sprang forward.  I think everything is good but I want a second opinion. The top of the tensioner is just a looped piece of plastic that rides in that channel right? There is no spring or anything is there? I got the gear and chain back on and it seems tight and everything looks right. I'm hoping nothing fell out.
    • My 2015 1500 LTZ Silverado suddenly won't go into 4 x 4 low. It will go into 4 x 4 high.
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
