Gonna need some massive tires on that thing to make it look proportional to those fender flares.  They look huge.
On 12/9/2020 at 9:21 PM, rjgti said:
that is the plan, when the wife permits it lol
Tell her I said it was ok.
    DaleB
    DaleB
  • Who's Online   6 Members, 0 Anonymous, 1,361 Guests (See full list)
