Not sure what you mean by "adapter".  If you want to adapt the OEM pucks to an existing hitch, check out the options on etrailer.com or contact your hitch manufacturer.
If you mean the entire hitch, then I have the Andersen Ultimate Hitch. It's aluminum and weighs only about 40lbs. My truck came with the gooseneck ball set (I think it's made by Curt).  The AUH connects to the gooseneck ball mounted in the OEM puck center hole. It tows my 12K lb fifth wheel like a dream. My previous truck  (Ram 3500 short bed) had a Pull-Rite SuperGlide hitch which was so heavy that it required me to use a hoist to get it in and out. The slightly longer GM standard bed and additional offset from the cab that you get with the AUH made it unnecessary for me to go with a slider hitch.
Edited by Njmurvin
    MASONV88888888
    MASONV88888888
  • Who's Online   4 Members, 0 Anonymous, 1,696 Guests (See full list)
    • I have 2 choices.
