Extended High RPM Cruising
firecadet613
Say I'm turning 3500rpm on my 4.3 v6 in the truck shown in the sig for a few hours while towing, will that do any harm to my motor or anything? Redline is at 5k.
Joe
Even though it's not near redline, that's still pushing the rev's imo. Assuming all basic maintenance items are taken care of I'd think you'd be ok. I'd just hate to wring that engine at 3500 for hours on end.
Roland
Roland
Thats my school of thought as well Roland, even though its not near redline, it's still pretty high, and I definatly don't want to damage my brand new motor.
Joe
My celica that I used to drive would turn 3K at 70, and I would take trips to houston turnning anywhere from 3-4k RPM (5k redline). It never minded that at all. Stop and go is what killed it.
The 4.3 is a d**n good motor, if it is in good working condition you shouldn't have any problems.
Don't worry about it,your not hurting anything.A friend of mine has a 98 3500HD box truck that he uses for work.The truck has a 454 with a 5.13 gear that spins 3500-4000 rpm on the freeway.It has 150k on it and other than sucking down massive amounts of fuel(5-6mpg) its like the Energizer bunny.Just do your regular maintenance and hammer down.
Just what I wanted to hear :mad:. My brother who's an electrical engineer but drives Fords told me it's a OK as long as I'm not near the redline. His trucks are all OHC so I wasn't sure if the same applied to me. I'm staying up in Evergreen Colorado now and make the drive down and up the mountain to Denver daily, but I'll be moving to Indianapolis next week and I might have to run it with OD off the entire trip due to what I'll be towing, but I can't possibly go 55-60 lol.
Joe
Awesome, how many miles were on that when you sold it/it died?
Joe
If I remember correctly, he had well over 200k on it when it died.
Well......Umm....How much are you towing?
Kind of a factor in how hard it's working to stay at 3500, right?
3500 rpm under a light load should be fine, but put around 6k lbs behind it, and you might be in for an expensive trip.
Just my .02
Joe
Speedo broke at 316K, motor died inbetween there and 350K.
My old 93 sonoma had the 4.3 and it had 128k on it before I traded. It spent most of it's life on the interstate cruising at 3k RPM's. It ran great and strong as can be when I sold it.
I think if you keep the maintenance up and a good quality oil and filter you will be fine. The 4.3 is pretty much bullet proof IMO. The boat 4.3's have roller cams, not sure when and if they installed a roller cam in the auto 4.3's. I know I cruise for a few miles in our boat at 4k with 5k being red line and it runs great. :thumbs:
A 72 Chev 1/2 T Pick-up truck with a 350, 4.10 rear-end, and a 3-speed auto (remember no lockup of TC) was doing about 3300 RPM at normal (i.e. 60 MPH) highway speeds. It redlined at just over 90 MPH. My dad's truck I abused in my early years of driving.
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
    • No, we trade them like pokeman cards.
    • It would be sold as a "kit", lights + auth/programming code.   You can resell the code to someone else, if they just buy the lights, either new or used, and they can then use the code to get them to work on their truck.
    • Apologies in advance, this is a long post, there's a lot to explain.   A friend had a 2010 Avalanche with a 5.3 (LMG) that blew the head gaskets (amount other problems). He gave me a donor motor out of a 2007 suburban (LC9). I got it all installed, and everything hooked up. Went to go start it, and it stumbled a bit at first and died a couple times, but after trying a few times it sounded like it was running very well. Went out to go get some coolant, and came back the next day.    Upon trying to start it, the truck will crank and fire normally and the RPMs will raise to around 1,200 or 1,500, sounding great, and then the RPMs will decrease and it will just die. Repeat that a dozen or two dozen times, and eventually it will fire and idle beautifully. As soon as you touch the throttle, it will start misfiring and sound like absolute trash. When you let off the throttle it will come down and hunt around shaking and misfiring like crazy. A message will come up on the dash saying reduced engine power.    It is throwing codes for a map sensor circuit voltage High, as well as MAF sensor low frequency. With key on engine off, the map sensor reads about 4.8 volts on the vout pin, which the PCM interprets as about 17.8 PSI, contrasted to the barometer which my scan tool tells me reads about 13.5 PSI. However, once the engine starts and is idling this reading drops to about 5-6 PSI at a stable idle, and varies significantly when the engine is misfiring/ hunting like I said before. I should note that I used the intake and MAP sensor from the LC9 engine. I changed the connector on the 2010 harness to The 2007 connector. The pinouts for the sensors were printed right on the top, and I triple-checked that I put the correct wire into the correct place.   On the other hand, the MAF sensor reads consistently 0.0 g/s regardless of State. I have pulled my hair out trying to figure out this last detail. I have tried three different sensors, (all of which should be good, one of which was new), I have verified all the wiring from the sensor going back to the PCM, and have verified that the readings at the PCM are the same readings as at the sensor itself. The intake air temperature sensor is also functioning as normal. I verified all the voltages and grounds etc, and everything is as it should be. I don't have an oscilloscope to verify, but I probed with my multimeter (Klein mm720) on frequency Mode, and it reads that on initial cranking, the maf is producing between 3000 and 7000 HZ, and as soon as the engine fires that falls off to below, 1000, and if the engine continues to run, it will produce somewhat erratic readings between 5 and 100-200 HZ. It does increase notably when the engine is revved despite the misfirings. As I said before, I have verified all of the wires going to the PCM, and I have tried multiple known good sensors. I've tested all the pins and voltages from the sensor and verified them against the manual that they are what they should be. I tested all the wiring for both ohms and voltage drop, and everything tested fine. Like I said I tested at the sensor as well as right at the PCM, everything checked out.   The only other thing of note at least I think is the fact that the engine originally in the truck had VVT, but the engine I put in, the lc9, does not have VVT. I modified the cam sensor plug to work. I reference the wiring diagrams and double-checked that I modified the harness correctly to adapt it. There is obviously a code for the VVT solenoid, but I don't think that's the cause of my problems, and this friend will probably have the PCM sent off to tune out the codes at some point.   I'm writing this for my bed so I don't recall the exact codes, but I'll update the post tomorrow morning with the exact codes. And ideas or feedback much appreciated.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
