Someone kicked in my rear electric sliding window.  What have others done to protect the back window from this happening?
Might not be the most appealing, but we use headache racks when it's possible for stuff to slide forward in the bed.
Thanks.  It is what I am most likely going to do.  Just wondered if there was a more subtle approach.
Maybe a big dog.
So then they just break a side window, if they want in they will get in.
Edited by Sick71
Hopefully a side window would set off an alarm.  Apparently kicking in the rear slider does not set off the alarm.  They got into the cab and rummaged the console but took nothing.  I'm actually pissed my alarm did not trigger.
    tararebecca
    tararebecca
  • Who's Online   2 Members, 1 Anonymous, 521 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
