2009 Silverado crew cab, 5.3L LC9 engine, 6L80E transmission.
Brake fluid keeps mysteriously slowly disappearing from master cylinder.  (Several small bottles of DOT3 over the last couple of years.)  When master cylinder gets half full, MIL lamp lights and Service Brakes Soon appears in DIC.  Brakes function normally, even when fluid level gets lower.
Local dealer says they THINK (?!) the master cylinder is leaking into the brake booster [they say to diagnose will require removal of master cylinder and brake booster and by then I'll be on the hook for a few hundred $], requiring replacement of both the master cylinder and the brake booster.  Does that sound right, that the brake booster would also need replaced?  Same dealer says I can't do it myself, because I would have no way to properly bleed the ABS brake system.  Is that correct?
I've driven many vehicles a couple of million miles, but I've never had a master cylinder leak before.  Drum brake wheel cylinders, yes, but not a master cylinder.
Thanks!
Yeah, that's a common issue. Since it's disappearing with no leaks anywhere, the only place it can go is out the back of the master cylinder and either down the front of the booster, or into the booster.
The reasoning for replacing the booster is the brake fluid severely degrades the rubber diaphragm in the booster. It makes it swell up and wrinkle, so it will take more vacuum to do the same amount of work. Not only that, but you know how they build stuff today. You could probably drive a truck from the 50's-80's, and early 90's for years with brake fluid in the booster without even knowing, but these days it'll reveal itself pretty quick.
You can do that yourself. They're full of crap. I've replaced them before without even bleeding the system after, although that's not recommended. When you disconnect the system that high up, alot of the time you can purge the air out with several very light, short pedal applications with a several minute break in between - you'll get the air bubbles to rise right out of the master. Real small bubbles that resemble foam in a way - you'll see them in the fluid. By bleeding, you're drawing the air DOWN. Much easier for air to go UP. You'll definitely need to bench bleed the new master, though before installation. I do it in the vise.
Edited by Jsdirt
  • Thanks 1
Just unbolt the master cylinder from the booster and pull the master cylinder forward enough that you can either see behind it, or can get a finger behind the master to see if it is wet inside the booster.  The only times I have ever had to bleed brakes at the wheels is when there was a part replaced after one of the flex hoses, or there was a complete brake fluid change to get rid of the water laden brake fluid.
Bench bleed the master before changing it, and leave the bleeder lines on (assuming they still supply a bleeder kit with master cylinders these days).
Bleeding at the master after installing it is not done the same as the bleeding at the wheels.  To bleed the master after installing it, do not pump the pedal, just loosen the lines, have someone press the brake pedal down and then hold the pedal down as you close off the lines.  Once closed, wait 10 seconds and have the helper release the pedal.  Wait another 10 seconds, then crack the lines loose about a half turn and have the helper push the pedal down slowly, making sure they don't pump the pedal.  Close the lines as the fluid comes out, and have the helper release the pedal after you have tightened the lines.  It should only require a couple of bleeds to get a good pedal.
^^^ That's the correct way to do it. My way is because I'm always flying solo here, lol. Would be great to have an extra set of hands in this place! ?
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   1 Member, 0 Anonymous, 455 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
