Good day everyone, I'm new here. I got a 92 gmc sierra k1500 with the 5.7 L. So my truck starts fine when cold, all normal. Once it reaches operating temperature it starts to shake or cause loping. I used the ALDL connector and wasn't getting any codes other than the 1,2. I'm really not sure what could be causing this issue as since it starts and runs fine till warm I'd think the fuel pump, filter, spark plugs, throttle body should be fine. I'm sort of leaning to a vacuum issue within the EGR system possibly. The EGR valve moves with my fingers with a bit of effort but not much.
Any help or suggestions would greatly appreciated. Thank you in advance.
  • 7 months later...
Is it cammed up? Haha, kidding aside, your idle air control valve might be dirty and sticking. Im not too sure how to get to it or remove it on these trucks but im sure there are plenty of youtube videos on it.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 353 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
