just curious how the ride is, currently have bilsteins cranked up and not a fan, just looking for 3.5ish of lift. 2wd truck with aftermarket uppers already. Just trying to justify the extra cost to go to the kings for almost double the price
https://www.4wheelparts.com/p/king-shocks-2-5-oem-performance-series-front-remote-reservoir-coilover-shock-absorber-25001-148/_/R-FBJG-25001-148
https://www.americantrucks.com/eibach-silverado1500-pro-truck-front-coil-overs-for-175-to-4-inch-lift-e86-23-032-01-20.html
    contrabombarde
    contrabombarde
  • Who's Online   1 Member, 0 Anonymous, 968 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
