Any snowmobilers in here?
Mega Dogmeat
I think I may be getting a new pair of sleds this christmas as a sort of "family present" ...
Anyways, my dad doesn't really wanna buy new, because we wanna get some powder sleds, and of course I want at least a 700 ;)
Anyways, we've been looking, and here's what I've come up with
I can get 2 1999 Yamaha MountainMax 700's plus a nice trailer for about $5,000 .... I dont know what the miledge is, as it wasn't advertised.
The pros of this is, the trailer I have is nearly 20 years old and while it works, has no 'front shield' and really could use some freshening up. The other part of this is, the current sleds I have are both yamahas, and the 340 Enticer I have finally gave up on me last winter after running rock-solid for about 23 years ... the 540 SRV i had ran for 18 years having the living snot knocked out of it every winter, so I'm pretty much sold on Yamaha quality ...
The second deal (which I'm giving some more serious consideration to) is a guy has a 2002 800 Polaris RMK, and a 2001 Polaris 700 RMK and he is asking $3500 each (I think I could probably talk this guy down to 6 for both) ... I have personally never owned an RMK, but I've never heard anyone whose had one have anything bad to say about them.... Polaris is a pretty reliable brand from what I hear.
So, if you were me, what would you look towards? I can use my old trailer for the RMK's if I get them, but it might be nice to have a better trailer too ...
I dunno, if you were me, what would you do if they were within $1000 of total price in each other?
The deal on the Polaris's is a good one. I have a friend with an 800 RMK and that thing rocks. The 02 800 books for about 5800 and the 01 700 for about 4700. If I were you I'd jump on em quick.I have a 02 600 Classic and love it. :jester:
    Greg3160
    Greg3160
  • Who's Online   5 Members, 0 Anonymous, 885 Guests (See full list)
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
    • Im in the same boat. Carlink adapter comes tomorrow and dev account is in process. Would you he able to send the new instructions my way also? Question, do you have to change code and republish app everytime developer updates? Thanks for your assistance, truly the only thing i cant stand about my truck is the carplay limitation
    • Parts department or service department at the dealer.
    • I’ll take the blue one!
    • And Google AI says......... Yes, your truck can technically handle it, but you will be right at or near its maximum limit. A 2016 Chevrolet Silverado 1500 High Country with a 6.5-foot bed has a maximum payload capacity of approximately 1,770 pounds.Weight RealitiesLoad weight: Half a cord of dry hardwood weighs roughly 1,100 to 1,500 pounds depending on the wood type (like oak or hickory).Payload limit: Payload includes the weight of the wood, you, any passengers, and a full tank of gas.The math: If you weigh 200 pounds and have a full tank of gas, a 1,500-pound load of wood puts you right at that 1,770-pound ceiling.Safety TipsCheck the yellow and white sticker on your driver-side door jamb for your truck's exact payload number, as high-end luxury trims with extra features have slightly lower capacities than basic trucks.Expect the rear end to sag noticeably.Drive carefully, avoid sudden turns or stops, and keep speeds low if you have to travel a distance.
