Is it possible to configure the cargo lights to come on in reverse but not when unlocked from the key FOB?  The high output cargo lights are great for backing in a trailer at night but they are blinding when walking up to the truck and loading the kids in the back seat.
I believe the Max Tow - NHT package has the ability for the cargo lamps (when pressed) to come on when in Reverse, Park, or Neutral.  But since I have a non-NHT then my cargo lamp only comes on when in Park.
Or is it possible to configure the cargo lights on a non-NHT to operate as the NHT to come on (when pressed) in Reverse, Park, or Neutral?
I use the diode method. Not sure if this is how you already have yours or not.509b0f5804178e0f8096e8523ec11c80.jpg
I also did the reverse/cargo diode mod, as well as the fogs/highs.  I had also done the puddle lights with interior lights mod, on my '15.  Some issues that I've seen over the last few years, getting the diode lead into the hole, diode installed backwards, diode plugged into the wrong hole.
If you only want the cargoes to come on in reverse (cargoes will still work by themselves), pin the diode (1N4004) the way that @bwlaqua did, stripe end in PINK26 (NOT 27, it's empty on most of them) and the other BROWN26.
Should you also want the reverse lights on with the cargoes, use a 14-gauge (solid) wire between the same two pins/wires.
I used the smallest tip jewelers phillips screwdriver or awl to "make an opening" along side of the pin in one of the corners, after fighting with them for a while.
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
