Hello, New Here.
Hello;
I just registered for this forum and just wanted to say hello. I took up re-building Chevrolet pickups as a hobby about 10 years ago. What I didn't plan on was that the hobby would turn into a demand for a daily driver. I'm on truck #5 right now, and I've learned a lot so far, but I've got even more left to learn. :jester:
I really enjoy the trucks and can't really decide which I like better: building them or driving them !
Anyway, I've got a few questions with relation to my latest rebuild project, so I hope its o.k. to ask them here.
Thanks in advance.
Chevywings.
Hey chevywings,
If you ever have any questions about a 88-98 rebuild give me an IM, I can help you with most stuff. While I have only been doing this for 5-6 years I have already stopped counting the number of trucks. So ask anything and maybe somebody knows. If we don't it will bug the crap out of us until we do, so you'll get your answer :D .
:rolleyes:
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
