will the wireing harnss from a 2006 chevy engine with  computer hook up to a 2000 gmc sierra  fuse box and power  up the engine
Edited by johnny brannon
more info needed to complete question
how hard is changing the trottle foot pedel to an electric fuel injection mine is a cable drive on the 4.8 and electric on the 6.0 engine
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 843 Guests (See full list)
