New truck delivered a couple of weeks ago. Tried to order one but didn't want to wait months. Laura had this in transit (one week out). Replaced my 2005. So far couldn't be happier. Little dirty but the only pic I have.
5 hours ago, CaptainMorganNC said:
How big is your garage?  It makes your at4 look small!
The garage is 40+ feet long. Built it for an RV/boat that I don't have and probably never will.
15 hours ago, CMillSilverado said:
I love mine too, at 2200 miles already!
Got some catching up to do...only 350 here.
I just bought one.  I feel the transmission can’t decide what gear it needs to be in low speeds(20-40mph). I’m moving over from a tundra which had none of those problems. Any thoughts. Only 1500 miles
Sorry no help here, 24k on truck and trans has been flawless. If you can duplicate during a test drive make an appointment with dealer and have tech go for ride with you.
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 283 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
